voltage at air conditioner compressor
Old Jul 26, 2009 | 09:52 PM
osduck5's Avatar
Default voltage at air conditioner compressor
What voltage should I be seeing on the wires going to the air conditioner compressor? I am thinking 5 but not sure. I am reading 1 volt with the ohm meter with air conditioner switch on MAX and the low pressure switch wires shorted together. I am trying to figure out if the compressor works or if there is something else that is not getting voltage to it. The clutch moves freely on it by hand. The a/c had no charge on it when we bought the car. Fuses show good, relay clicks but I have not had a chance to ohm it out.
Old Jul 27, 2009 | 01:01 AM
should be able to switch the relay with any of the others except the abs one. they are all the same but the abs. switch with one u know is working. if failing the problem should follow the relay. u should be getting a code.
Old Jul 29, 2009 | 09:13 AM
Masospaghetti's Avatar
I would expect 12 volts, but am not sure...I can check the wiring manual when I get home.
Old Jul 29, 2009 | 11:36 AM
The PCM operats the AC compressor relay. The relay then puts out 12 Volt to the AC compressor over the green wire, the black wire goes to ground. The pressure sensor is wired directly to the PCM it receives 5 Volt from the PCM and ruturns 0 to 5 Volt to the PCM, depending on pressuer. You can connect 12 Volt, through a 30 AMP in line fuse, directly from the battery to the compressor. If the clutch is good id should lock up when you give it battery.
Old Aug 3, 2009 | 08:36 PM
osduck5's Avatar
Ok, thanks. I will try to check it with a 12 volt source to see if it engages. As usual, work is getting in the way of camaro-ing!
pcarollo
Aug 1, 2015 08:50 PM
jbarnett
Apr 27, 2014 10:36 AM
Kendagenius
Aug 27, 2011 05:08 PM
AKLDan2k1
Aug 25, 2011 09:28 AM
pilgrimbrit
Feb 21, 2008 11:21 PM
