abs inop
Old 10-11-2008, 09:58 AM
MusicMan's Avatar
The Jazz Man
Default RE: abs inop
Which years had abs front and back? I've been running shorter tires on the back for a long time now, and never had the light come on. I always thought the ones with drum rear ends only had front abs.
Old 10-11-2008, 10:26 AM
I believe that the 97 still had the ABS IV system (as in previous years), which has a speed sensor on each front wheel, but just one sensor on the rear differential. Later years had sensors on all four wheels. Not positive, but I'm gonna say the four-wheel sensor system (ABS VI) may have started in 1998, since all models now had 4-wheel disc brakes.
If you have ABS (97 and older) you should see a little black module on the outside of your rear axle, top side, near the center section.
Old 10-11-2008, 12:19 PM
jurmy2's Avatar
I have this ABS INOP issue too, my back axle is bent and it makes the light mad lol
Old 10-11-2008, 04:54 PM
MusicMan's Avatar
The Jazz Man
I've got a 96, so I must only have wheel sensors in front. That would explain it.
zeusz28
09-27-2012 06:57 AM
camaro girl
12-09-2008 06:47 PM
thetal1
09-28-2008 02:21 AM
TEXASMAN1
04-23-2008 03:41 PM
bonedeth631
03-04-2008 07:47 PM
Quick Reply: abs inop
