99 Camaro need help!!
Old Sep 15, 2010 | 11:49 PM
aldie's Avatar
Default 99 Camaro need help!!
Ok, I want to start off by saying I dont know much about cars at all. But, im starting to get interested more and more ever since I bought my camaro. I have a 99 3.8L v6 and its an automatic. I have a job, and im saving up so I can make my car as fast as possible. So what do you all suggest I start out doing to it to make it faster? Cold air, headers, anything? Thanks.
Old Sep 15, 2010 | 11:52 PM
Chaotic94's Avatar
September 2011 ROTM
Full exhaust system from the headers to the tips will do alot of good. Cold air intake and a bigger cam as well. throw some 3.73 gears in the back too! A good tune to go with all that will help. You might want to get a shift kit and beef up that tranny too.
Old Sep 16, 2010 | 08:04 AM
1stindoor's Avatar
As stated...start small...work your way up to bigger (read...more costlier improvements).
New exhaust
CAI
Better Tires
Stiffer suspension
Old Sep 17, 2010 | 09:47 PM
mrfreez's Avatar
How fast do you want to go? What's your goal?
How much do you want to spend? What's your budget?
Here's some ideas:
- Swap the tranny for a standard 5spd
- Put in a Stage-II clutch
- Swap the rear-end for 3.73 with posi
- Get headers
- High-flow cat
- Performance muffler
- Higher-capacity fuel pump
- Higher-capacity fuel injectors
- Cold Air Intake or RAM Air (like the SS)
- Wider low-profile tires
- New wheel bearings
- AC Bypass pulley & remove AC compressor
- Computer tune
- Synthetic oil
- Aluminum one-piece driveshaft
Old Sep 19, 2010 | 11:21 PM
aldie's Avatar
Alright guys thanks. Is there any websites that you all recommend me buying from?
Old Sep 19, 2010 | 11:35 PM
aldie's Avatar
And where can I get it tuned at?
