Hole in the Grommet behind the PCM
Old Sep 19, 2010 | 06:04 AM
AbbandonZK's Avatar
Default Hole in the Grommet behind the PCM
I have a hole in the grommet behind my PCM, its a small thin slit hole which a amp power cable is being ran thru. Can anyone recommend a caulking agent or should I just leave it as it is? Thanks
Old Sep 19, 2010 | 06:50 AM
does it look like it has potential to leak? could use a dab of silicon on it or something simple to remove like a glob of grease.
Old Sep 19, 2010 | 05:56 PM
AbbandonZK's Avatar
Its not a hole its more of a slit will any silicone do or does it have to be some special high heat stuff?
Old Sep 19, 2010 | 11:02 PM
traumadog's Avatar
Regular should be fine - shouldn't be that hot in that corner.
Old Sep 20, 2010 | 01:00 AM
AbbandonZK's Avatar
Thanks for the info guys
Stevolwevol
May 21, 2015 09:13 PM
lightningcruiser
Apr 20, 2013 08:58 PM
dogdog130
Jun 19, 2011 09:05 PM
Gmed1990
Nov 4, 2009 06:56 PM
