98 3800 - Alternator Mounting Bracket - Need Help
Old Aug 13, 2011 | 12:43 PM
Inverted's Avatar
Default 98 3800 - Alternator Mounting Bracket - Need Help
I took the engine apart over a year ago. I am just now getting it all back together. I have two pieces that I believe mate up to the alternator in some fashion. I can't figure it out, I need some help. If anyone can describe how they go together that would be great. If you happen to have some pics that show me where they go that would be even better. The L shaped bracket in the link below is one of the brackets.
ImageShack® - Online Photo and Video Hosting
Here is what the second bracket looks like.
95-02 CAMARO FIREBIRD 3.8 L V6 RH ALTERNATOR BRACKET | eBay
Thanks a ton. I can finally see the light at the end of the tunnel!
Old Aug 13, 2011 | 01:02 PM
Massey's Avatar
THe first pic actually bolts to the head and helps support the back of the alternator. There is another piece to it that I dont see there.
I cant see the E-bay listing at work so I cant comment on that one yet.
Massey
Old Aug 14, 2011 | 04:47 PM
milkinit's Avatar
The second pic is of the complete assy, the first pic is the back half. This assy bolts to the back of the rt side head and behind the middle injector, two bolts then hold the two parts together and also bolt to the back of the generator. The tab on the outside of the front part of the assy holds vac controls.
Attached Thumbnails 98 3800 - Alternator Mounting Bracket - Need Help-hpim0920.jpg   98 3800 - Alternator Mounting Bracket - Need Help-hpim0921.jpg
94z28chevy
82-92 V8 Tech
May 3, 2013 11:58 AM
exlimey
Aug 21, 2012 09:03 PM
socalrs
Feb 6, 2012 04:55 PM
kjvforme
Jun 26, 2011 01:02 AM
DCorey
Aug 17, 2010 11:47 AM
