97 3.8L camaro Loss of power and shaking
Old 11-02-2011 | 10:49 AM
Originally Posted by iLLControl
You could always do what this dumb a_ss did
Nothing dumb a$$ about it at all really. Good plug wires shouldn't arc and spark like that. And a little water isn't going to hurt good wires.
A "leaky" wire can even spark to a ground if there's humidity in the air, but it might be hard to spot depending on where it's located.
Old 11-02-2011 | 01:25 PM
iLL95's Avatar
I Like to Party
Super Member
Oh, well it just didnt look right to me, looked like it could cause some pretentious damage in the long term!
Old 11-02-2011 | 04:16 PM
Naaaaah, doing that just gives the spark a different way out.
Now, grabbing that sparky wire with your bare hand...... that would be a dumb move!
Old 11-02-2011 | 08:58 PM
Spatfieya's Avatar
...Done that before.
Old 11-03-2011 | 03:47 PM
CCj's Avatar
CCj
Thanks for all the replies I took it out today to try and narrow the issue down and the car had no issues. so that means the problem is caused when the engine gets hot . I also noticed after letting it idle for 15 mins there was water leaking from the brace underneath the cat converter and a lot from the muffler. Would a likely cause of the engine trouble be coming from a plugged cat converter. /crossfingers i hope not
Thanks for the help
Coil packs changed no difference spark plugs/wires good. gotta pick up a new fuel filter
josh H.
06-21-2015 12:06 PM
djordan
03-25-2012 10:32 AM
80z28guy
70-81 V8 Tech
01-04-2010 10:51 AM
LT1RUNNER
12-04-2007 10:45 AM
gijoe985
10-13-2006 11:58 PM
Quick Reply: 97 3.8L camaro Loss of power and shaking
