power loss
Old Dec 3, 2007 | 12:19 PM
LT1RUNNER's Avatar
Default power loss
I realize that there is another thread here with "jackjonson" camaro needs to be restarted in order for the power to return. I didn't want to ***** up his thread. I have a similar problem with power loss only my car has it all the time. One day I noticed a change in the way the engine sound but I didn't think anything of it until a few days ago. I too cannot burn rubber from a dead stop and my car has been using up a lot of fuel and the gas fumes are very strong. The engine is a 94 LT1 with only 20k on a rebuild. Opti is new as well as the wires and coil (MSD). There is no check engine light on and the cat is new. Any help would be great! Thanks.
Old Dec 3, 2007 | 04:16 PM
Default RE: power loss
Assuming that the engine is running rich, then check the fuel pressure & pressure regulator. If they are OK, take a good look at the O2 sensors with a scanner & see what they are doing, if anything. The rich running may have fouled your plugs so you should take a look at them & replace them if necessary. Also, if you have a scanner take a look atthe output of all other sensors & see if they are reasonable. Also check the knock sensor output and the amount of spark retard, if any.
Old Dec 3, 2007 | 05:43 PM
LT1RUNNER's Avatar
I forgot to mention that I did replace 02 sensors when I did the rebuild. I don't have a scanner so to the nearest shop I go. How do I check the presure regulator? Never did that.
Old Dec 3, 2007 | 06:40 PM
There is a sticky in the Lt1 section on how to test the regulator. You will need a cheap FI pressure gage, around $25.
Old Dec 4, 2007 | 10:45 AM
LT1RUNNER's Avatar
That would cause that much power loss?
josh H.
Jun 21, 2015 12:06 PM
djordan
Mar 25, 2012 10:32 AM
x01660
Mar 9, 2011 10:18 AM
80z28guy
70-81 V8 Tech
Jan 4, 2010 10:51 AM
gijoe985
Oct 13, 2006 11:58 PM
