97 3.8 catalytic converter
Old May 9, 2011 | 02:18 AM
Massey's Avatar
Hmm... Never heard that the sensors are going to be too sensitive to high flow cats on the 3800. GM's cats are pretty efficient on this engine and the gains from high flows are minimal so the sensors should be fine. If you are rattling inside the cat then yes get a new one. If MD is plugging a device into the OBDII port they are getting your emissions readings too. The OBDII port can not only deliver codes, be used as a programing port but it also gives out the emissions data so they dont have to put the sniffer up the tailpipe. Keep a cat in there and you may want to see about changing the rear sensor after replacing it.
Massey
Old May 9, 2011 | 03:28 PM
Originally Posted by 3800camaro
because the air flows through it faster then a stock cat making it harder for the sensor to get a correct reading. its not a problem with obd1 cars but the obd2 cars are alot more sensitive to this.
It is not a problem with OBDI cars because OBDI do not use downstream sensors, and OBDI does not look for one.
Old May 9, 2011 | 05:29 PM
EasternStryker's Avatar
I think I am going to try a high flow cat and see what happens.
B_Dubya
Jul 17, 2015 09:26 AM
skinut
Feb 21, 2010 10:37 AM
AmirGTR
Jun 8, 2009 05:26 AM
bobc04
May 5, 2008 09:15 AM
kwwrestler
Mar 16, 2008 07:37 PM
