96 camaro problems
Old Dec 28, 2008 | 09:10 PM
psycho209's Avatar
Default 96 camaro problems
I have a 1996 Camaro Rs 3.8 and the guy i bought it off seemed like they didnt take care of the car. Some hoes are not connected and some things are taped up and jst a mess
can anyone help me and tell me what this part is called and/or tell me where i can get it (a hoes goes on it and ones releases and the other sucks in air. it has the hoes but the hoes is way to small and i cant find the part for it).
thats one i also need a new or good used housing where the air filter goes because it seems like it is broken and i also need the clips to hold the housing together. can anyone tell me where i can find some for cheap?
It also hasahoes that that is jst dangeling and i cant find where it goes (not the hoes from the above discription)
I really need some help. thank you
Old Dec 28, 2008 | 09:19 PM
02StanGT's Avatar
Default RE: 96 camaro problems
Have you tried putting the tubing/hose from the second pic on the vacuum port/hole in the first pic? I just went and looked at my engine, and that looks like that would work. The line in the second pic should run to a sensor/switch which is mounted on a bracket above the passenger side valve cover.
Old Dec 28, 2008 | 09:29 PM
Liquid1's Avatar
I will go and take some pictures for you tomorrow. Let me know if there is anything else you need pics of.
Old Dec 29, 2008 | 04:53 AM
evilkal's Avatar
Your wires look like they've been through hell and back again... Get us some more pics and explain the problem a bit better...
zblad
May 9, 2010 02:19 AM
smithdjr
Oct 11, 2007 09:46 AM
NFG687
Mar 5, 2007 07:20 PM
73maro
Mar 1, 2006 03:27 PM
hunterd557
Feb 17, 2005 09:24 AM
