95' V6 3.4 Won't start. Please Help!
Old Aug 8, 2010 | 06:25 PM
Devon's Avatar
Unhappy 95' V6 3.4 Won't start. Please Help!
I was driving, then it seemed as if the gas pedal wasn't doing anything, the oil pressure dropped to nothing, then my engine started shaking all in a few seconds. I pulled over and checked out under the hood. The serpentine belt was partially broken off and the rest was still on but hanging halfway off. So I bought a new serpentine belt to replace the other one. Tried starting it up; it turns over but turns off in a second. Still no oil pressure. I've done a little bit of research on google and I think it might be the distributer or the spark plugs, but im no car expert. Anyone ever had the same experience or have any idea of what the problem might be? I need this fixed asap!
Old Aug 8, 2010 | 06:31 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
To correct you, you have coil packs, not a distributor. One of those could be going bad, or it could be a spark plug/wire. When is the last time you replaced those?
Old Aug 8, 2010 | 07:11 PM
Devon's Avatar
Thanks for the correction, as I stated before i'm not a car expert. What are coil packs? I haven't changed the spark plug wires since I have owned the car (2 years).
Lakatrae
Mar 29, 2014 10:59 AM
rdb357
Mar 30, 2008 08:25 AM
JTyler
Aug 31, 2007 10:21 PM
coco
Aug 13, 2007 10:33 AM
