95 Camaro starts funny
so i recently bought a 95 camaro 3.4l 5 speed. when i go to start it it sounds like the battery is low. Had the battery starter and alternator tested everything check out. any1 have an idea of what else I should check.
Make sure all battery cables and grounds are not corroded, and the connections clean and tight. Check the cable connectors for corrosion betwen the connector and the actual cable. Check voltage across the battery posts with the engine running and all electrical stuff turned on, should be no less than 13.8 Volt.
