egr valve
Old Apr 12, 2008 | 12:41 PM
peter's Avatar
Default egr valve
i ve been havin some problems with my gas 3.4 engine ive changed alot of stuff new 02 sensers ,headers, exhaust, air kit,TPS park plugs and wires all of its performance parts and im still gettin bad gas milage so i consider its the egr valve and i did put 5w 30 oil into the engine with 135000 milesi probably should not have done that the lifters do make a sound when i start to accelerate. its still runnin goodno power loss jus when i start thecar i hear a noise from the egr valve and smell gas.when i turn the car off i hear the egr valve makin a noise
Old Apr 14, 2008 | 04:55 AM
brucehusker's Avatar
Default RE: egr valve
I'm struggling with my EGR valve as well, same engine, almost identical miles. Two quick questions...what are your mileage figures now and are you getting a "service engine soon" light coming on? With mine, it seems to run fine but the light comes on periodically and then goes out. I did try taking it off and cleaning it, but I'm not sure how good of a job I did in retrospect. If you do buy a new one, be careful that you get the right one. I've noticed that online parts stores often show a non digital valve in their picture, even though it's listed as the correct one for our engine.
Regards...Bruce
Old Apr 14, 2008 | 11:22 AM
peter's Avatar
myy service engine light doesnt come on ive never seen it come on since ive had and if i do buy one ima goin to buy it from autozone and what do u mean by mileage figures
Old Apr 14, 2008 | 12:05 PM
you said you were getting bad milage and I was curious what you consider bad. I get 28-29 mpg highway with mine and hope to make a few mods to do a little better. If your "SES" light isn't coming on, I would suspect that your EGR valve isn't the problem. Are you sure it's making a noise?
Bruce
Old Apr 14, 2008 | 01:17 PM
peter's Avatar
im probably getting 15 mpg ive been puttin gas in it every couple days and im not driving much. when i start my car i hear a noise comin what sounds like the egr valve and i smell gas when i turnthe car off then i go up to the egr after i turn ed it off its makin a noise
Old Apr 14, 2008 | 04:34 PM
Where is your EGR valve located on your engine? Does this diagram show what you're referring too?
[IMG]local://upfiles/9762/2B1FE7C6CB634DCF9843922E660B47AC.gif[/IMG]
Old Apr 15, 2008 | 07:40 AM
terrychamp01's Avatar
number 4 r 5 and it sputters alot and when i first start driven it sometimes goes past the thermestat limit by like 20 degrees i smell gas everytime i put it in park r maybe get out of my car
Old Apr 15, 2008 | 01:54 PM
That's a head scratcher for sure. You might take it a trusted mechanic and see what they say.
Regards...Bruce
Old Apr 15, 2008 | 02:06 PM
Labyrinth9's Avatar
what is the question here? it sound like your EGR is failing. there are liek 7 threads about EGRs that have been dont in the past month. jsut look around youll find your information.
Old Apr 15, 2008 | 08:47 PM
grover's Avatar
ORIGINAL: brucehusker
Regards...Bruce
Bruce, I'm having pretty much identical symptoms to you. My 94 3.4L has 160k miles, but I've been ignoring the SES light for several years now- would have started around 125/130k or so. I've had no noticible difference in power or mileage, though it did start this high pitched squeal about 6 months ago coming, seemingly, from behind the EGR, that sounds pressure related (increases in pitch with rpm but lags when rpm reduces quickly) and correlates with what I'd expect from pressure/actuation in the EGR valve. I haven't been able to pinpoint the cause- may be a reflection of the sound, or something completely unrelated. I replaced the O2 sensors, which worked for about 2 days, then the SES light started coming back on.
I'd intended to break off my EGR and clean it out, but the bolts are rusted on there pretty damned good. If you fix your problem, please post back!
