95 Camaro 3.4 won't start
Old Nov 10, 2012 | 06:22 PM
mudjunkie's Avatar
Default 95 Camaro 3.4 won't start
I bought a 95 camaro 3.4 , the wiring harness was toast, looks like one of the fuel lines had a pin whole in it and the kid i bought it from used black tape to fix it . well it didn't and burnt up a good section of the harness , I went to a junkyard and found the same exact car which I was able to get the wiring harness , EGR sensor, MAF sensor , ECU , and vac lines, have it all hooked up but can not get the car to start .
I have spark and there is power going to the injectors but I do not know if they are pulsing . fuel pump is not coming on when I turn the key , but if I jump the prime lead I hear it run and pumps fuel , I tried jumping the relay and that also gets the pump to work but car still wont start . if I spray starter fluid into the intake if fires right up but quits as soon as the starter fluid burns off .
I have checked every fuse in the car that I can find and also replaced the fuel pump relay and am lost as to what to try next .
Old Dec 4, 2012 | 06:16 PM
mudjunkie's Avatar
Well site was'nt much help but I ended up finding the problem on my own , it was the orange wire that runs from #8 PCM Fuse had power at both sides of the fuse and in the orange wire going into the harness but not making it to PCM once I fixed that it fired right up . Hope this helps someone else
Old Dec 4, 2012 | 06:51 PM
for anyone looking here for help. see if this helps. https://camaroforums.com/forum/93-02...18/#post618955 found in the how to and faq sticky at the top of this section. sorry your thread got by me.
mrZ
Aug 1, 2012 08:29 PM
sixpack_sid
Apr 27, 2009 08:44 PM
bwest05dm
Mar 9, 2009 08:50 PM
girl_gordon24
Jul 11, 2006 06:52 PM
