94 3.4 problems
Old Jun 29, 2007 | 04:42 PM
Nate's Avatar
Default 94 3.4 problems
My buddy has a 1994 RS with the 3.4 in it, while driving home from work the car bogged down and the cat converter overheated and was cherry red. after getting the cat replaced the car now will sometimes not start, and once started it runs very rough and very rich. we replaced the camshaft sensor, the o2 sensor, and the fuel pump was recently replaced as well.
please dont give me the 'newb' treatment, im doing a search as well. any info would be helpful. thanks
-Nate
Old Jun 29, 2007 | 04:55 PM
libertyforall1776's Avatar
Default RE: 94 3.4 problems
Try spraying some throttle body cleaner into where the air intake enters, plugs & wires, fuel filter...
Also could be your air temp sensor...
Old Jun 29, 2007 | 05:09 PM
Nate's Avatar
thanks, ill give that a shot
Old Jun 29, 2007 | 06:20 PM
The reason the cat overheated is because too much raw fuel was getting dumped into it. Apparently the engine is running excessively rich. Could be a fuel injection problem, especially the pressure regulator, an injector stuck open, ignition misfire, or as previously mentioned, a bad sensor. Get the car scanned & look for active and retained codes, and point you in the right direction.
Old Jun 29, 2007 | 11:01 PM
Clean the injectors with the Lucas Injector Cleaner... may need a few treatments...
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
