3.8L, White Smoke at Cylinder Head
Old Apr 8, 2012 | 02:40 PM
the motor is not hard to change when you do it from the bottom. leaning how is the hardest part. lol. it took me a while the first time cause i didnt want to break anything. installing was a breeze. went so smooth i had to keep stopping thinking i was forgetting something.
does not have to be this high up
Old Apr 8, 2012 | 03:12 PM
Sounds like a nice car. Auto or Manual?
You can do the above with just a normal cherry picker engine lift, I did it with a 1 ton HF one.
Check out the thread that explains where you can get motors from https://camaroforums.com/forum/93-02...nt-info-57568/
Old Apr 8, 2012 | 04:05 PM
overgrownmoose's Avatar
I've got access to a shop with lifts, so height is no problem. About how many hours would you guess? Can you do most of it with one man? It's a manual transmission. Brand new clutch before all these motor problems too, ugh.
Old Apr 8, 2012 | 09:20 PM
My guss for a good non-pro would be about 20 hour, That is switch everything over to the new motor but that will completely depend on you. A pro using air tools and a real lift I would guess 12-14 hours.
Old Apr 8, 2012 | 10:35 PM
Well, I've got access to a shop for $5/hour with plenty of lifts and air tools, plus mechanics to lend a hand when needed. Being a soldier has a few perks, but this is undoubtedly the one I use the most.
Turbo33
Dec 3, 2011 11:05 PM
REN
Oct 11, 2010 11:09 AM
Stix80
Aug 6, 2009 09:48 AM
Albatross
Feb 28, 2008 09:41 AM
T10wheels
82-92 V8 Tech
14
Nov 4, 2006 02:57 AM
