3.8 Oil Pressure
Old Jun 9, 2014 | 04:03 AM
cheap fram filter can fail and cause loss of pressure.
Old Jun 9, 2014 | 08:38 AM
Sophm's Avatar
I used fram the first time then a purolator. It had the same oil pressure effect.
Old Jun 9, 2014 | 09:12 AM
do like you said and change the filter and have a look see inside it.
Old Jun 9, 2014 | 10:20 AM
Sophm's Avatar
Should go to the more larger filter ph52?
Old Jun 9, 2014 | 10:35 AM
i dont think it will fit
Old Jun 9, 2014 | 05:43 PM
fbodyrs96's Avatar
Acdelco 52 we'll fit
Old Jun 11, 2014 | 08:38 AM
Sophm's Avatar
I change the filter and got 3/4 on gauge on start and little under 1/2 when warm. With Rpm's it goes over half a bit right know.
Does the oil housing relief valve bypass the filter and go though engine or dump back in oil pan?
Ill post back when I cut old filter open.
Old Jun 11, 2014 | 08:52 AM
wow, so you just changed the filter and not the oil?
Old Jun 11, 2014 | 09:01 AM
Sophm's Avatar
Yeah only the filter. I went to the Purolator L24011 it longer then the L10111 so hopefully it wont clog as quick since it can filter more if thats whats happening.
Old Jun 11, 2014 | 10:10 AM
  #20
kool, purolator is a really good filter. we is pulling for ya.
