3.4 mods
hey guys im new here ive been apart of www.f-body.com they know their stuff pretty good but i like to always get extra opinions. i have a 3.4 with underdrive pulleys, high flow cat, flowmast dual outlet, and k&n drop-in. what else can i do cheap to get a little more out of the car?
yes when i put the pulleys on you will notice a little bit of an acceleration out of the hole. all i did was crank not WP. but if you stall your car up to around 2k then let it go you will notice a difference and lower rpms on the highway i cruise 80-90 at about 3k-35
These can help with general performance and longevity: Add a Prestone flush kit, and do the Super Flush fluid, check for leaks, check/replace thermostat, fuel filter, air filter, add fuel system cleaner for a couple tanks, use a throttle body cleaner spray. Switch to synthetic oil, and Dexron 6 Trans. fluid -- replace your Trans. filter if not done in many years/miles.
