3.4 hard start when hot
Old 07-16-2010, 06:15 PM
rt_180's Avatar
Default 3.4 hard start when hot
I have a 3.4, recently noticed that it is hard to start after shut-off when it's at normal temp. It cranks over but end up having to hit the gas to start, then it runs fine. It fires right up when cold or sitting for a while. I've not been able to locate any v-leaks, and the plugs and wires are fairly new, within 10 k miles. Any insight?
Old 07-16-2010, 11:07 PM
mrfreez's Avatar
My guess would be the injectors. For some reason there's not enough fuel in the cylinders so the fuel is burning faster than the cylinder gets filled. When it's cold, the pump injects fuel into the cylinder before starting the car. Try running a good fuel treatment through the car or put in 1/3 can od Seafoam in the gas tank.
Tommyboyink
10-20-2011 12:11 PM
Mj3039
02-16-2011 02:42 PM
1974z28
10-08-2009 07:17 AM
ohbhave
05-31-2009 04:44 PM
kyphur
03-21-2009 02:32 PM
Quick Reply: 3.4 hard start when hot
