3.4 to 3.8 series 3 supercharged
Old Oct 30, 2006 | 03:53 PM
94v6's Avatar
Default 3.4 to 3.8 series 3 supercharged
can i pull my 3.4 **** box engine out and simply change exhaust system, and computer to support a 3.8series 3 supercharged engine? like is it worth it? does anyone know where i can find a 3.8 series 3 supercharged? just kickin around the idea pricin options.
Old Oct 30, 2006 | 06:50 PM
94CamaroSFI's Avatar
Default RE: 3.4 to 3.8 series 3 supercharged
the supercharger will not fit... it will not clear and you can't cut anything to make it fit due to the windshield. Get an Lt1 or a non supercharged 3800
Old Nov 1, 2006 | 05:23 PM
In other words, NO! However, you could try a Buick GN turbo motor, if you can find one and have the know how to make it work.
Old Nov 3, 2006 | 01:57 AM
AlfredB18's Avatar
I wouldn't even bother with a Buick turbo 3.8L.
If the OP has to pass emissions, that's probably not gonna happen with that engine if a visual inspection is necessary.
For the trouble of changing an engine and tranny, along with the electronics, just slap in an LT1 drivetrain pullout and call it a day.
Old Nov 11, 2006 | 12:33 PM
dblack1's Avatar
ORIGINAL: 94CamaroSFI
i believe the l67 (supercharged 3.8) isnt any taller than the l36(na 3.8 for fwd, i dunno if the rpo on the rwd is different), the biggest problem that i think u would have is the intake, because the throttle body comes out the back of that engine.... if ur gonna try to make the switch (which u shouldnt because of the throttle body, its gonnna cause u major problems), u should try to get a series 2 instead of a series 3 because of price, ease of installation (series 3 has a electronic tb), and performance parts availability.
if ur gonna pay that much for an engine save urself the trouble, and the pain, get a ls1 its about the same price.
Curt705900
15
Feb 4, 2013 01:34 PM
vinnyfirstblood
Sep 19, 2012 09:30 AM
SinCity-7T4
Oct 25, 2011 04:56 PM
Bandit 43
May 28, 2011 12:05 AM
cmchambers7
82-92 V6 Tech
Mar 22, 2011 05:29 PM
