series 2 carrier to series 3
Old Feb 3, 2013 | 11:33 PM
Curt705900's Avatar
Default series 2 carrier to series 3
So i have a 94 Z28 and im looking to give it some more get up and go. From what i've read, getting it re-geared is a magnificent way to get it some more performance, but from what i read that i need to have a series 3 carrier for getting it geared higher. My choice of gearing i want is 3.73 compared to my 2.73's
But my knowledge on the carriers are a bit weak. So what i would like to know is how i can make this gear swap happen. Like were can i get a series 3 carrier, what do i have to do to swap it. Like a step by step walkthrough if anyone would may.
Old Feb 3, 2013 | 11:39 PM
BasicConcepts's Avatar
Technical User
Replacing a carrier is hard work, its not a hard job but its very important to know what your doing as you could really destroy your rear end. You could always just replace the whole axle with one from a manual Z28, it should have 3.73s in it factory.
Old Feb 4, 2013 | 10:36 AM
Chaotic94's Avatar
September 2011 ROTM
^ 4th gens didn't come with 3.73's. Only the M6 cars came with 3.42's. The autos came with 3.23's or 2.73's...
On a more appealing note to the OP:
You can get 3.73 gears sets for the series 2 carrier at SummitRacing.com. They'll hold up better than the series 3 gears sets as well because they're thicker!
Here's a link to a set of series 2 3.73's:
Search Results for gm 7.625 series 2 3.73 - SummitRacing.com
Good luck in your search good sir!
Old Feb 4, 2013 | 11:49 AM
Technical User
Hmm, why did I think they came with 3.73s...
Old Feb 4, 2013 | 11:55 AM
Chaotic94's Avatar
September 2011 ROTM
Cause you're a noob! Lmao
Old Feb 4, 2013 | 12:11 PM
Curt705900's Avatar
So basically buy the kit and install it without screw anything up. (or let the shop install it for more $$$)
Old Feb 4, 2013 | 12:13 PM
Chaotic94's Avatar
September 2011 ROTM
The kit will have the gears, new bearings, crush sleeve, etc.. You can buy that but I recommend having someone who is experienced with differentials install it for you. It's pretty easy to mess it up and grenade your rear end if you've never done it before.
Old Feb 4, 2013 | 12:24 PM
Technical User
Well damn I learned about the rear ends from you so...
Old Feb 4, 2013 | 12:25 PM
Chaotic94's Avatar
September 2011 ROTM
I've told you like 5 times that 4th gens never had 3.73's haha
Old Feb 4, 2013 | 12:28 PM
What does B.C. know, he's a "Honda Guy"!
