2000 Monsoon question
Old Jun 25, 2006 | 01:14 PM
freekmccoy's Avatar
Default 2000 Monsoon question
My wife just bought a 2000 V6 and it has the Monsoon 6speaker setup..
I've been reading about the 2 way front speakers(both of them sound like crap) the drivers side sounds like its just playing the tweeter and the passenger sounds like the bass is busted on it,the two speakers by the passenger seating don't have any sound at all,and the two in the trunk area sound fine for being 4"(I assume these are for highs)
From what I understand the headunit runs the tweeters and the amp runs the subs
where is the amp located?is it built in or somewhere else on the car? other posts I've seen says to look in the panel by rear passenger wheel well...looked didn'ts see amp there just spare tire,and a security sensor...
any help would be appreciated..thanks
Old Jun 25, 2006 | 02:21 PM
94Z28SHAKER's Avatar
Default RE: 2000 Monsoon question
look at the back seat speakers, i bet there's not even speakers in there.
and the amp for the rear is on the left hand side inside of the bass box.
there are amps attached to the front door speakers, all speakers are run by amps in your setup.
Old Jun 25, 2006 | 02:44 PM
freekmccoy's Avatar
yeah there are speakers there I took one out and tried a spare I had with the same results..
"left hand side inside of the bass box" not sure what you referring to here...[&:] driver or passenger side?and not sure what you mean bass box..
mine has the two 4inch speakers over the wheel well...
thanks for replying
Old Jun 25, 2006 | 03:54 PM
drivers side in the trunk, there should be a little box that the sub sits in, the amp is inside of the enclosure, the front speakers- the amp is attached to the speaker's inside of the door.
hope that helps ya!
nouturn20
Jul 5, 2012 02:55 PM
Mikey.
Feb 12, 2012 07:37 PM
kda66
Feb 6, 2012 11:48 AM
sh2002
Aug 16, 2007 10:44 PM
