2 engine questions
2 engine questions
1. How much does an ignition coil usually run for a 3.8? new or used...
2. ill post a pic once fiance gets home if there is enough light, but there is a white plug with a blue cap between wheel well and exaust manifold on the passenger side, what is it for? i found it resting on the manifold and wanna make sure it isnt major as it slightly melted but dont know if it messed up anything
1. a Aftermarket coil like msd would be around $45 and a stock around $20, new.
2. I know what connection your talking about but im not sure what its for. There should be a little black plastic pin on the connection that holds in against the wheel well.
