Eurolamps.com
Old Aug 19, 2010 | 09:09 PM
trigger987's Avatar
Default Eurolamps.com
Has anyone ever dealt with this website before?
I ordered the sealed beam conversion kit and for some reason I feel like I have been hustled
Old Aug 19, 2010 | 09:45 PM
libertyforall1776's Avatar
They are terrible with responses to questions. Instead check this out:
http://www.speedinc.com/catagory.cfm?catagory=Lighting
They have a kit with the conversion -- really all you need is the conversion housing, then order your HIDs from DDM Tuning -- that's what Speed Inc. is selling, even though they won't tell you beforehand.
Old Aug 19, 2010 | 09:52 PM
trigger987's Avatar
Yeah problem is i already ordered from them
and yeah I was planning on getting my HIDS from DDM anyways, except i had a question with that is well,
Do i get the raptor kit or the slim ballast kit? or is that all on personal preference?
http://www.ddmtuning.com/Product-Cat...hting/HID-Kits
Old Aug 20, 2010 | 10:35 AM
Slim is what I have on both , low beams only so far, and is the newer technology (digital) and smaller. But either are ok. Note you may need to reverse your factory plug to the ballast, as mine has reverse polarity, and would not light until I did.
I got 55watt & 5K bulbs - nice and white, and more light output compared too the blueish ones.
Old Aug 20, 2010 | 11:00 AM
mrfreez's Avatar
I ordered this and I am very happy with it:
http://www.eurolamps.com/eurolamps/c...headlights.htm
Old Aug 20, 2010 | 11:23 AM
trigger987's Avatar
Hey mrfreez, how long did it take you to get them?
Old Aug 20, 2010 | 11:53 AM
There's another place mentioned on LS1Tech for those conversion housings, which I read were better -- forgot the name, though...
Old Aug 20, 2010 | 11:55 AM
trigger987's Avatar
Hey liberty, you said something about reversing the factory plug what exactly do you mean?
Old Aug 20, 2010 | 02:07 PM
^ normally the plug snaps and locks with that tab, when you reverse polarity it won't snap and lock on anything, so if you are concerned about it, just get a thin tie-wrap around them.
See:
https://www.ddmtuning.com/support/in...cleid=26&nav=0
" Reverse Polarity
If you install your HID kit and they do not turn on you may have reverse polarity. What this means is the power and ground wires are your vehicles stock harness are reversed. What you will have to do is plug the harness connector into the ballast backwards. You will be plugging in the connector from your car into the kit backwards. This will not harm the vehicle or the kit.
Note: Reverse Polarity is an issue with the cars wiring not the HID kit. Some cars come from the factory wired in an orientation that is reversed when compared to the HID kit. When using stock halogen bulbs, polarity has no effect, therefore, some manufactures will have the power and ground wires opposite of the HID kit. Some manufactures will have reverse polarity more then others. A lot of GM models have reverse polarity."
Old Aug 20, 2010 | 09:51 PM
trigger987's Avatar
Makes perfect sense now, thanks for the detailed explanation
btw eurolamps replied to my message, my closed beam conversion kit should be here soon, thought i threw 88 bucks down the drain for a few days
