1998 v6 Automatic Camaro Issues
On one hand, the guy offering the more optimistic look at it (the flex plate/converter problem) is a guy I know personally. So there's the fact that he may just be saying that to keep my hopes up, but then maybe since he's a personal friend, and the other's not, the other's just trying to rip me off 4300 bucks..which'd suck..
Checking to see if the cat is plugged is a simple test. Cracks in the flex plate can be tuff because then can crack around the crank bolts. I dont know how to expain it but the flex plate has a more "tinny" sound.
Well we're gonna get it lifted up for ourselves and look around in the inspection hole, try replacing the catalytic converter and a few other things. Also thinking about taking the spark plugs out one at a time to test if there's a cylinder not working correctly or something.
It's definitely in good shape otherwise, even the mechanic we took it to agreed for it's year. The dealer we bought it from said they'd put in all new valves and what not and the previous owner has a dual flowmaster exhaust system on it. I'd like fixing it if it isn't too costly. But let's say it is a bad catalytic converter. What might have been the cause for it going bad? (beside it possibly being low-grade, leaded gas) Don't really want it happening again.
YouTube - ‪Rattling - Catalytic converter?‬‏
Made a video of what it sounded like when I'd rev it.
Well..Case closed I guess..I took it to an official Chevy dealer the other day, he took a look at it and told me the lower bearings were shot basically..Getting a new engine in about a day since I know a guy who could install it for me for like 500 dollars..Is what it is I guess
#20
Its the motor. No doubt about it. Are you putting in a new motor? Did you find a used one? $500 is pretty cheap for the install. If it is a used motor you want to get the intake resealed. It is a very common issue with the 3800 and the job is a pain with the motor in the car and a quick job with the motor out.
