1996 Cruise control won't work v6 3.8
Old Dec 1, 2008 | 12:22 PM
crazy8taylor's Avatar
Default 1996 Cruise control won't work v6 3.8
I bought this car a couple weeks ago. Checked the fuse and its fine. Was told the module has been changeg out. Was told maybe the cable was stuck. Where can i find a trouble shooting guide that wire show wiring & cable replacements. No light appears on dash when button is pressed. Can it be the cruise/turn lever?
Old Dec 1, 2008 | 03:18 PM
02StanGT's Avatar
Default RE: 1996 Cruise control wont work v6 3.8
No light ever appears when you turn cruise control on. You might check to see if it is even hooked up to the throttle... The throttle body should have to two cables running to it on the driver side.
Old Dec 2, 2008 | 07:18 AM
It has two cables. One goes through the fire wall into the driver compartment. The other goes under the front left tire area. Not for sure it the module is located there. Goes into a area covered by a mug flap/cover.
Old Dec 2, 2008 | 08:59 AM
02StanGT's Avatar
Check the third brake to see if it is working. That being out can somehow cause the cruise control to quit.
Old Dec 2, 2008 | 09:03 AM
MusicMan's Avatar
The Jazz Man
I'm curious about my cruise control also. When I got my 97 pcm from pcmforless, it stopped working.
Old Dec 2, 2008 | 09:13 AM
02StanGT's Avatar
Q: Why has my cruise control suddenly stopped working?
A:
Check the third brake light. It seems some cars with a blown brake bulb will disable the cruise control system. If this is not the problem, then check with your dealer as there is a Technical Service Bulletin (#569002A) for this which calls for replacement of the cruise control module with an updated one. Apparently, the stepper motor is too sensitive to input from the brake pedal switch causing it not to work at all.
That is what I found for on a FAQ about f-bodies
Old May 17, 2010 | 09:54 PM
tam85's Avatar
cruise control system has a lot of functions. it can accelerate or decelerate the car by 1mph. replace it asap to avoid any problems on your car.
___________
cruise control lever | ~tammy beede~
Old May 18, 2010 | 01:27 PM
BasicConcepts's Avatar
Technical User
check vacuum lines the cruse is completely controlled by vacuum
Old May 18, 2010 | 02:11 PM
thetal1's Avatar
That thread was made in 08
Grandpaswagon
Mar 16, 2021 12:49 AM
madmax32
Jul 24, 2012 04:17 PM
llll1lll1
Mar 1, 2012 09:08 AM
ryguy425425
Apr 16, 2010 08:56 PM
