1995 v6 wont start
Old Jun 22, 2014 | 10:06 PM
check all your wiring harnesses around the burnt area. wiring get brittle after getting so hot
Old Jun 23, 2014 | 05:52 AM
kingmoon2142's Avatar
All wires seem to be okay and the volt meter say thay all have connection to where ever they go I been testing plugs to ecm
Old Jun 23, 2014 | 08:09 AM
sounds like your gona have to invest in a pcm/ecm 100 bucks for 3.8, less for 3.4
Old Jun 23, 2014 | 11:26 AM
Does the new ecm have to be programed
Old Jun 23, 2014 | 01:25 PM
programed to your vin number. other than that i think your ok.
Old Jun 26, 2014 | 05:51 PM
Ughhhh im going to throw a brick tho the winsheild and run it over with a truck new ecm still wont run I need ideas things that go bad any thing will help where does the sig come frkm to ground out the injectors
Old Jun 26, 2014 | 07:00 PM
Whats an easy way to bypass the vat system
Old Jun 26, 2014 | 08:40 PM
Wheres the self deturgent module
Old Jun 26, 2014 | 09:02 PM
anti theft module located
Old Jun 26, 2014 | 09:04 PM
  #20
GaryDoug's Avatar
The theft deterrent module is inside the instrument panel just to the right of the radio and attached to the air bag bracket. But even to bypass that, you wouldn't need to access the actual module, only the wires under the steering column going to the key cylinder.
