1995 camaro on crack
Old Mar 14, 2012 | 06:03 PM
dogdog130's Avatar
Default 1995 camaro on crack
i have a 95 camaro has 280K on here 3.4 lt well it starting to be stupid sometimes when i am at a light the camaro just dies all u hear is the fuel pump whineing out but the thing has a half a tank any ideas
Old Mar 14, 2012 | 06:06 PM
is the check engine light coming on. have the car scanned for trouble codes. that may be tough being you have a 95, its got a obd1 computer with a obd2 port. depending on the whine it could be the fuel pump. check fuel pressure. can usually use or rent a fuel pressure test gage at your local parts store,
Old Mar 14, 2012 | 06:18 PM
dogdog130's Avatar
i dont have the thing to scan it it is a obd2 with a obd1 computer and the whine is coming from the pump and then u smell rubber
Old Mar 14, 2012 | 06:23 PM
look at numbers 14, 33 and 24 here 4th Gen LT1 F-Body Tech Aids
MN79Camaro
Oct 16, 2011 11:13 PM
boostedzx3
Aug 26, 2009 11:23 AM
350rs
Jul 8, 2007 09:26 PM
zachyfarms
82-92 V8 Tech
May 2, 2007 09:00 PM
