Back from the dead...
Old Mar 13, 2012 | 09:05 PM
'96Teardrops's Avatar
Default Back from the dead...
I have a '96 3.8 Camaro that has been barn stored for the last 4 years. It has problems, but ran strong when it was put up. I am now in a position, time and money wise to fix it and enjoy it. The car is a keeper, the body is straight and the interior is like new. But...it won't run except for a brief instant and then it quits like the key was turned off. Then it has to sit awhile before any kind of life is evident. The gas tank is almost full of 4 year old gas, so if that is the problem (I suspect that it is at least partly to blame), what is the easiest way to drain the tank so I can start fresh? Besides that, does anyone have a suggestion on what my next place to look for a cause should be?
Old Mar 14, 2012 | 09:12 PM
Spatfieya's Avatar
Get a pump and suck it all out best way you can, or drop it.
If you're going to rebuild it, I'd spend the extra time and drop it and clean it out.
1998camarossclone
May 11, 2013 11:05 AM
RS camaro
Dec 3, 2010 05:57 AM
Ownage1100
82-92 V6 Tech
Feb 19, 2010 03:29 PM
Opticon
Apr 29, 2009 01:33 PM
