1995 camaro 3.4 v6
Old Jun 8, 2008 | 09:02 AM
meteoralp45's Avatar
Default RE: 1995 camaro 3.4 v6
id check your fuel pump and filter as mentioned. i had something similar happen with my car, it would bogg down and then get going, and sometimes even shut off, my collant temp sensor was bad and it was pretty much telling my car that it was cold, causing it to dump fuel into my motor, thus flooding it and causing it to bogg down and occassionally cut off
Old Jun 8, 2008 | 06:24 PM
camarogirl1's Avatar
here is a update did full tune up,starter,fuel filter also put fuel system cleaner in the gas tank. the next thing will be the coil packs. thank you for all your help and i will keep you posted.
Old Jul 2, 2008 | 07:09 PM
come to find out i need a fuel pump and a tank need to know if a fuel pump and tank will work off a 97 firebird please help need to know tonight thanks
Old Jul 2, 2008 | 07:11 PM
Old Jul 2, 2008 | 07:12 PM
Camaroforlife
May 7, 2012 09:14 PM
alex_mia35
Nov 10, 2010 11:40 AM
glenn511365
Sep 14, 2008 08:22 PM
camarogirl1
82-92 V6 Tech
Jun 3, 2008 08:46 PM
