1995 camaro 3.4 v6
Just bought a 1995 camaro and already having problems. well having trouble starting it,put in a new starter that did not help and when you accelerate it bogs down then speeds up very slowly. i heard it could be the master air flow senser,computer or the coil packs.
RE: 1995 camaro 3.4 v6
I think 3.4 used Manifold Absolute Pressure (MAP) sensors, while the 3.8 used the Mass Air Flow (MAF) sensor with a MAP backup. Is the Check Engine Light on?
no check engine light on
You know how long it's been since it's had a tune-up (new plugs, wires, fuel filter, etc.)?
just did plugs,wires and starter but still having starting problems to
Have you checked your fuel pump and the fuel lines Seems like your car is not getting appropriately
Also if your fuel filter is not clogged up with carbon build up.
i have heard that my trans could be going. please dont tell me that!
Does the engine itself seem to run normal?
Sounds like a coil. Replace all three and the ignition module. They take a real beating from all the engine heat.
