1994 Camaro v6 Speedometer Calibration
He changed his rear end,so the speedo cant differentiate with it, that's the only vibe im getting
He did the same rear swap I did. The VSS is in the transmission, so the only thing affected would be a slight variation in mph readings on the dash due to the higher gearing.
pull the vss and see if you have gears or a reluctor. check here http://www.transmissioncenter.net/sp...n_______va.htm
It was accurate before I swapped my rear ends. After the swap, it's 5-7mph off. I'm about to go to 3.73 gears from my 3.42's and I want a way to calibrate it so that it's still somewhat accurate.
lol might be a couple days. I'll let you guys know what I find.
