1993 3.4 - Security Light Flashing - Auto
Old Jun 1, 2010 | 08:43 PM
xxthekidxx's Avatar
Default 1993 3.4 - Security Light Flashing - Auto
Ok , let my girlfriend drive the camaro for the first time down to the gas station, first mistake. she calls me up and says the car wont start. so i drive her honda down and I see the security light flashing,
-left the key in for 30 min. no change
-disconected the batt. for 20 min no change
- got a new key today, no change
I remember reading that you could bypass the ignition reading the code from the key by twisting the yellow and purple wire together but that was for a 95. Just wondering exactly what to do so I dont screw this up.
Old Jun 1, 2010 | 08:54 PM
mbar's Avatar
have you tried leaving the key turned on but not starting for 30seconds then turn off remove key for 3 mins then try to start it... or maybe even wipe the key off maybe there is some sort of dirt on the resister chip on the key...
Old Jun 1, 2010 | 09:21 PM
xxthekidxx's Avatar
Yes i've tried that and i also got a new key, i believe i can do what is described in this diagram correct?
Old Jun 1, 2010 | 09:30 PM
mbar's Avatar
as a last resort i would try that... i had a similar issue with my 95 but my key was dirty
Old Jun 1, 2010 | 09:34 PM
mbar's Avatar
return the key and try another....where did you get the key from?
Old Jun 1, 2010 | 09:59 PM
xxthekidxx's Avatar
I brought my old key to the chevy dealership and payed like 26.00 to get a new one. he scanned it before making the new one.
Old Jun 1, 2010 | 10:11 PM
mbar's Avatar
ok...i was gonna say get one done at a dealership, but i would say if nothing else has worked then i would say go ahead and bypass it but be very careful
Old Jun 1, 2010 | 10:30 PM
xxthekidxx's Avatar
Why is that, what am i getting myself into? is it not just cutting the wire and putting a resistor in?
Old Jun 2, 2010 | 07:26 AM
mbar's Avatar
well anytime your dealing with cutting or splicing wires its important to be careful cause anything can happen...
richard.nelson100
Jun 22, 2014 10:19 PM
JGuy07
Jun 12, 2012 03:34 PM
2000 Camaro Ridah
Sep 7, 2010 09:28 PM
Leeet
Sep 8, 2009 04:16 PM
skibee
LS Series Tech
Apr 4, 2007 04:07 AM
