WS6 Rearend
Old Sep 14, 2012 | 08:33 PM
cclovern's Avatar
Default WS6 Rearend
Hello to all I have a chance to pick up a GU5 G80 rearend used for a good price. I have found some details on this site , what should I look at for a used unit ? Any seals I should change before change out ? The data I found shows it's a 3.23 gear and heavy duty posi unit any inputs ?
Old Sep 14, 2012 | 08:34 PM
cclovern's Avatar
Forgot to include the intended recipent 1993 Camaro Z28 A4.
Old Sep 17, 2012 | 04:14 AM
maudyZ28's Avatar
got one of these in my 99.
Proiblems you may encounter:
Brakes are different, are these inclused on axle with brake hoses?
3-4 channel ABS/ASR, sensors may not swap/ may need wiring in or a hole drilling in top of axle case for 3 way ABS only sensor on a 4 way rear end (WS6 are usually 4 way)
If you can change seals your self and they look weepy then do it. Mine was a good low milage unit and nothing needed changing, just a bolt in.
Check pinion play if it moves a LOT it might not be any good, you need to compare this with yours
Old Sep 17, 2012 | 09:34 AM
GreenMamba's Avatar
Just curious, but whats the difference between this rear end, and the stock one? I have a 94Z, and it has 3.23 gears and posi already.
Old Sep 17, 2012 | 09:46 AM
MKCoconuts's Avatar
Depending on the year it came out of, the style of the LSD and the brakes are different. Other than that, the ABS/TCS (ASR for Camaro) may be different. In the end though it's still a weak 10 bolt...
Old Sep 19, 2012 | 06:41 AM
cclovern's Avatar
Thanks to all for the input , I'm gonna pass on the rearend. The build sheet I found shows posi and 3.23 gears. I thought I had a problem with the current rearend it was clunking when put in gear. Found the tranny mount was broken , replaced it and changed diff oil and cover gasket , all seems fine. Will put the $200 towards a Sphon 12 bolt inthe spring.
Old Sep 29, 2012 | 04:42 PM
Greg08's Avatar
Yes! I love camaros
DiggityDavee
11
Jun 2, 2014 08:09 PM
gofastturnleft70
Feb 12, 2012 05:47 PM
1989fbody
Aug 15, 2009 04:35 PM
Racer111
Sep 8, 2007 01:48 PM
Chappie99
Jul 6, 2007 04:24 AM
