Rearend help
Old Jun 27, 2007 | 06:26 PM
Chappie99's Avatar
Default Rearend help
Friday I am removing a rearend froma 95 Z28 convert.to replace my 99, 3.8 5 speed. Any guess or info on ring gear size of the 95 as to the size of my 99. Also any tricks on removal, seeing its a junkyard rearend, I would like to have everything available before I end up stuck..They wont allow any torches, so I think a sawzall and my tools should be ok.. Any helpful tools that may be needed that any of you guys have found make this job easier. Thanks.
Old Jun 27, 2007 | 09:31 PM
Chappie99's Avatar
Default RE: Rearend help
Are rearend problems taboo.....Everytime I post a question about "rear differentials" nobody ever replies...Do we all just know from the trans foward???????????
Old Jun 27, 2007 | 09:57 PM
JD1969's Avatar
No it's just many of us don't bother with weak stock 10 bolt rear ends. Plus you only waited about an hour and half for a responce. That z/28 had either a 2.76 or optional 3.23 gear if it is an auto, 6 speed cars all had 3.42's. There might be a tag on the diff, or you can write down the RPO codes,m which should be on the glove box door or a sticker in the door jamb.You hand tools and saws-all should be all you need.
Old Jun 28, 2007 | 11:51 AM
oZcar's Avatar
need to replace rear end seal. how do i pull the axle out. 96 camaro 3.8 drum brakes
Old Jun 28, 2007 | 06:21 PM
JD1969's Avatar
ORIGINAL: oZcar
It is considered very rude to hijack threads, start your own in the V6 section.
Old Jun 28, 2007 | 07:43 PM
Chappie99's Avatar
I have asked rearend ?? many times with little to no response...I figured if I acted a little rude, someone would respond.
ORIGINAL: JD1969
Old Jun 28, 2007 | 10:41 PM
The ABS won't work after you swap rears. The new one works on a 4 channel system and the old one works on a 3 channel system. Also, before complaining that no one is helping you, consider what you are asking. Get a repair manual first and read it, and then ask questions if you don't understand something.
Old Jul 6, 2007 | 04:24 AM
Chappie99's Avatar
Thanks Pete...I ran into many brake issues during the swap...I by no means am a "WLB" that is a whinely little biach...sorry ifI came off that way. On the repair manual...Thanks for nothing chiltions...Man I wentto my library and researched through everybook I could find just to find some specs..and nothing.
Great answer on the ABS...Pete you must be a GM tech or have lots of experience. Again, thanks..
ORIGINAL: z28pete
DiggityDavee
11
Jun 2, 2014 08:09 PM
gofastturnleft70
Feb 12, 2012 05:47 PM
DADZ28
Jan 20, 2010 06:47 PM
1989fbody
Aug 15, 2009 04:35 PM
Racer111
Sep 8, 2007 01:48 PM
