What transmissions fit?
I have a 1995 5-speed Camaro but the 1st gear sychro is gone and reverse is going out I believe. It is a 3.4L and I was wondering which vehicles also had a transmission to fit. I was thinking maybe an S10 but I'm not sure.
I am not sure if the T-5 transmissions like the one in your car have removable tailhousings like the 700R4/4L60/4L60E have but if not your only option as far as I know would be another one from a similar Camaro. Camaro's have a torque arm that bolts to the tail housing of the transmission that aren't on other GM cars so whatever you use will have to have the 3 mounting holes for it. Hope this helps.
Here is a good place to start for info: TECH: Ultimate T-5 Article - THE H.A.M.B.
This is based mainly on using T-5's for older Ford swaps but has some very useful info about GM platforms as well.
I'll trade you my 95 caro transmission it works I just took t took it out thinking my motor was bad
