700r4 transmission
Old Dec 8, 2009 | 02:13 AM
stealthwizard89's Avatar
Exclamation 700r4 transmission
hello if i get a 700r4 tranny out of a pickup or a chevy blazer will it bolt up the same and fit my 1988 camaro or does it half to be out of a camaro/firebird fbody of that generation ?
Old Dec 9, 2009 | 07:28 AM
muddyman184's Avatar
I dont see why not v8 to v8 should but i think v6 and v8 wont bolt up but if your close to the east coast mainly like PA NJ DE i have a 700r4 that came out of a 91 v8 and has around 20k my buddy paid around 1500 and now its sitting in my garage i want nowhere near that much just trying to help
Old Dec 10, 2009 | 01:05 AM
sewerrat's Avatar
I'm not sure if the c/k series trucks 700r4s have the correct extension housing to mount the stock torque arm. If your donor trans doesn't have the mount then you'll either have to swap one from a 3rd gen or use an aftermarket torque arm and mounting kit.
Old Dec 11, 2009 | 10:53 AM
Jr. Mechanic's Avatar
August 2009 ROTM
IIRC you can use one from a pickup if you swap the tail cone over from your current transmission.
Don't quote me though.
Old Dec 11, 2009 | 08:15 PM
microkid's Avatar
March 2011 ROTM
Technical User
it will bolt up to the engine, but i cant say about the rest. there are no torque arm provisions from the trucks, and they are typicly 4wd and have a different tail section to bolt up to a transfer case. if it was pulled from a 2wd, it might have a longer tail shaft. easiest way to do it to stick with one from an f-body
Old Dec 11, 2009 | 08:43 PM
mighty mike's Avatar
they will fit no prob, but as stated b4 u will have to change tail housing for the torque arm, also make sure the speedo drive still cable and not eletric. other than that itll fall right in. done it.
Sinclairaity
Aug 28, 2010 09:49 PM
knightrider1632148
Mar 19, 2009 11:21 AM
Blue79ice
Jan 25, 2008 04:17 PM
73 T Top
Apr 22, 2007 01:07 AM
Booder
Sep 5, 2006 08:50 PM
