transmission shift kit
Old Sep 12, 2006 | 06:30 AM
Saint_Ali's Avatar
Default transmission shift kit
i was thinking about getting a shift kit from b&m for my 93 camaro, its supposed to make the shifting better and smoother, has anyone used this before ?
Old Sep 13, 2006 | 09:41 PM
Default RE: transmission shift kit
It will make the transmission shift harder. I am not sure about the smoother part. Kinda hard to have both conditions at the same time.
Old Sep 14, 2006 | 02:45 AM
Saint_Ali's Avatar
so is it not worth getting then ? will it ware the transmission out more than with out it ?
Old Sep 14, 2006 | 07:16 PM
The hard shifts will probably make the tranny last longer by eliminating slippage, but the rest of the drivetrain and rear suspension takes a beating. Personally, I don't like shift kits on a street car, because I like to cruise in moderate comfort.
Old Sep 15, 2006 | 12:03 AM
1969 SS's Avatar
if your trans is weak to start with, a shift kit is going to kill it quickly. it doesn't fix problems, it just makes everything firmer and if the trans isn't strong, its' not going to be able to take the added load
bvans
70-81 Transmission & Differential
Jul 20, 2010 01:56 AM
roscoSS00
LS Series Tech
Jun 12, 2010 10:00 PM
cron091
Jan 26, 2010 05:02 PM
-Tommy-
Jan 21, 2010 01:33 PM
odatdamkidagain
Feb 4, 2008 08:54 PM
