Trans Issue
Old Feb 18, 2012 | 08:03 PM
Chevy_Guy2005's Avatar
Question Trans Issue
Well Lets Get The Whole Story Out First Off
7 Months Ago...
No Issues At All But An Optispark Code
Got Off The Highway ANd Came To A Stop Sign
Take Off And First Second And Holds In 3rd....
End Up Parking It For The Winter
Change Optispark And Test Drive
Same 1,2, and holds 3
Hook-up Snappy Scanner And Read Current Gear ANd When You First Start Off It Show 1... 2.... 3.... Never 4th And Once It Gets To 3 Never Gots Back To 1 on scanner
Few Weird Things Puts Out A Code 79 Which Has Trans Temp Too High But When You Read The Data Everything Looks Fine
Fluid Looks Normal And No Burnt Smell
Any Ideas????
Thanks All
Old Feb 19, 2012 | 08:05 AM
is your speedo working? test tps. check the wiring and plugs to the trans
Old Feb 19, 2012 | 02:02 PM
Speedo Is Good
TPS Reads At All Points
And Plugs All Same Tight
Old Feb 19, 2012 | 05:47 PM
if everything checks out i would say its in the wiring inside the trans. might try resetting the shift cable. 41 on the list here 4th Gen LT1 F-Body Tech Aids
Old Feb 20, 2012 | 09:19 AM
I Will Looking Into That Today... That Would Really Be The Best Way To Say What The Car Is Doing To A T...
All Gears It Shift Are Strong Just No Up Shift To 4th Just Like If You Were Selecting 3rd
flowride
Apr 2, 2013 01:26 PM
Ron93LT1
11
Mar 29, 2012 10:58 AM
olered
Nov 13, 2011 08:52 PM
libertyforall1776
Sep 13, 2011 12:28 PM
