swapping a rear end
Old May 6, 2020 | 07:06 PM
prock's Avatar
Default swapping a rear end
hi there, I was just wondering if anyone knows about swapping a 2002 ss rear end with a 3.42 ratio into a 96 z28 with the same ratio, I was just wondering if the wheals, suspension, brake lines and traction control line up the same, thanks
Old May 12, 2020 | 09:29 AM
there are two types of rear ends. traction control and non traction control. it is easiest to keep them the same. if your current rear end has one sensor hookup at the center section its non tc, if it has sensors at each wheel then its a tc rear. if the 96 is the same as yours its a simple switch.
Wess001
Apr 5, 2015 12:42 PM
BasicConcepts
May 3, 2010 06:42 PM
GSchubes
Apr 10, 2010 08:41 PM
Landonus
Apr 12, 2009 11:43 AM
84Z28
Jan 30, 2007 01:44 AM
