Slave cylinder loose?
Hey guys I'm stuck in Raleigh (live in Charlotte) right now because my clutch is sticking. Bled the line and it didn't fix the issue, but when I wiggle the clutch line where it goes into the slave cylinder it's loose. Is this normal or is my slave loose and that's my problem. It is a 2001 Firebird trans am. Thank you
If the line is not leaking it is probably ok. The master cylinder can fail and cause the clutch to not disengage but so can the clutch pressure plate itself.
A slave cylinder can fail but that will result in a leak.
