Reverse is royally screwed.
Old Feb 17, 2011 | 09:36 PM
  #31
you better get a factory service manual for your yr.
Old Feb 17, 2011 | 09:45 PM
  #32
Chaotic94's Avatar
September 2011 ROTM
That requires money, which I don't have any of... Do you have one for my year?
Old Feb 18, 2011 | 03:30 PM
  #33
DarkKnight's Avatar
GTO Killer
LimeKnight
you take your shifter out by removing the consoul, then theres a plate with 4 bolts, one on each corner, pull those and the plate should lift up with the shifter and all, you may want to get that the two bolts that hold your stick in proper location are both there and tightened... i had a problem with mine, one was out and one was lose, and i couldnt get the car into rev. because the path to rev is so tight do to the lockout system, hope that helps at all
Old Feb 18, 2011 | 05:18 PM
  #34
Old Feb 19, 2011 | 12:59 PM
  #35
Chaotic94's Avatar
September 2011 ROTM
I found the 4 that make the shifter come loose but I couldn't find the other two. I think that maybe my car has a different shifter than you LS1 had... Any other ideas? BTW the shifter looked out and so did the internals.
Old Feb 19, 2011 | 01:21 PM
  #36
Jesu Christo man, did you even look at the link I posted? Scroll down to page 90, it shows an exploded view of your trans. And the following pages show a tear-down starting with the shifter removal.
Old Feb 19, 2011 | 08:45 PM
  #37
Chaotic94's Avatar
September 2011 ROTM
Yes sir I see it. The pics are small and I'm not mechanical savvy. So I got the shifter out. Everything looks okay there. Now I need to take out the shift linkage and see if its bent I guess. Right?
Old Feb 19, 2011 | 09:37 PM
  #38
evilkal's Avatar
Judging by the first post only.... It sounds like you have a shifter linkage issue. It's likely because your trans is half an inch lower than it should be. That happened to me with my Camaro and it torched my torque converter.
Get a transmission mount that is made for your car and see if it improves. If it doesn't, you probably damaged the linkage. Reverse does not have a syncro so if your linkage/shifter will not fully engage the gear, it will pop out instead of go into gear.
The humming is due to reverse being straight cut and not syncro'd btw.
Old Feb 19, 2011 | 09:40 PM
  #39
BasicConcepts's Avatar
Technical User
Old Feb 19, 2011 | 09:50 PM
  #40
Chaotic94's Avatar
September 2011 ROTM
That's what I figured. How hard would be be to replace the shift linkage/fix it? Is it something that I could do myself?
Aldo BC, that's a great price on that tranny. It would probably cost $300 to have it shipped though.
