Rattle under car at start-up
Old Aug 7, 2019 | 10:24 PM
DaveM's Avatar
Default Rattle under car at start-up
Hey I get this rattle at start-up under the car; seems like it is coming from just below the drivers seat. I am thinking maybe it is the heat shields clanging, because it doesn't make any noise after that.
Any ideas other than heat shield that can cause this? Leak in the exhaust system?
Old Aug 8, 2019 | 06:15 AM
The Cat itself can rattle if it falls a part inside. A bump on the cat(s) with a rubber mallet when its cold should tell you.
Old Aug 8, 2019 | 09:16 PM
DaveM's Avatar
would it be noisy only on start-up or noisy the entire time the car is running?
Old Aug 9, 2019 | 08:45 AM
Depends on how bad. Normally when they first fails its just cold. As the internals get hot and expand it goes away.
Old Aug 14, 2019 | 08:45 PM
Zspoiler's Avatar
I would put it up on a lift and or jack stands to see what it might be.
Camaro3800V6
Nov 13, 2019 06:33 AM
camaroxguy
Sep 8, 2011 07:36 PM
2kcamaro
Oct 1, 2008 09:49 AM
EddieTheRipper
Oct 11, 2007 08:57 PM
JaySan
Jul 12, 2006 08:15 PM
