quick trans question
#33
no i just took the hose and a soft brush to it... anyways theres no serial numbers on that sticker but in the lower rear corner theres a badge with some numbers ill get a pic
#34
so i was in the middle of the install about to take a pic for my how to and i dropped my fone and cracked the lens so no write up
but on a good note this kit is pretty easy to install
#35
what do you guys think of recycling trans fulid??? ive got a trans full of 50 mile old fluid. i was thinking i could get some pantyhose and double them up and filter the fluid through that than run a magnet through it as a double check
#36
what do you guys think of recycling trans fulid??? ive got a trans full of 50 mile old fluid. i was thinking i could get some pantyhose and double them up and filter the fluid through that than run a magnet through it as a double check i have a REALLY strong magnet the only way to get it off the side of my tool box is to pry the corner up (its square) and use piece of wood under it
#37
Is that the trans that was slipping on you, and probably burning up the clutches? For what you're going to save, it's not worth the chance of still having grit in the fluid once you're done. Not to mention, the cost of replacing your nylons (we're don't ask, don't tell here)! Treat the new tranny to some new fluid.
no its the trans that was working perfectly than went boom and then didnt work
ohh and i got plenty of hose
#38
lol, I know, you've gone through so many tranny's, I lost track. If you're convinced to go that route, be sure to use the panty hose with the cotton panel. If it's good enough for.....eh never mind!! lmao. But still, I'd go with new fluid.
