Need Help....Ring and Pinion Questions??
Old May 15, 2012 | 04:59 PM
randyf's Avatar
Default Need Help....Ring and Pinion Questions??
I have a 98 SS, I believe it has a 3:42 rear end.
I want to change to a 4:10 or 4:11 rear end.
What do I need to look for.....what is the ring gear size and I think I read something about thinner or thicker ring gears??
I just want to make sure I buy the right thing.
Thanks for any advice.
Old May 15, 2012 | 06:41 PM
Old May 16, 2012 | 08:46 AM
Cheeks's Avatar
August 2011 ROTM
becaredul putting that much gear in a 10 bolt rear, especially being that you have a 6 speed. The 10 bolt isn't exactly the strongest rear end out there (with a 7.5" ring gear) with that much gear in it and a couple hard launches, you could very easily blow that thing apart, but it will be fun while it lasts!!
IndianScout
Aug 28, 2013 08:11 AM
randyf
Jun 2, 2011 11:46 PM
kisk
May 8, 2008 08:50 PM
chevy_man
Apr 6, 2008 09:56 PM
Cannedbil
Jun 21, 2007 12:25 PM
