Limited Slip Diff Is Shot???
Old Apr 17, 2013 | 11:08 AM
Chaotic94's Avatar
September 2011 ROTM
Default Limited Slip Diff Is Shot???
I put a LSD rear end in my Camaro from a z28 Camaro and when I first put it in, if I spun one tire by hand while the car was jacked up, the other tire would spin the same direction. Now when I spin one tire while the car is jacked up, the other tire spins the oposite direction.. Did I blow the limited slip clutches out of the rear end???
Old Apr 17, 2013 | 01:49 PM
Try holding the tire from spinning backwards and see if the LSD engages. Some time it takes a bit of load on both tires to get the clutches to catch. If that is the case you may want to change the rear lube before going for the gusto.
Old Apr 19, 2013 | 09:12 PM
Everett#2390's Avatar
Put one rear tire on the ground, trans in neutral, and if torque wrench shows less than 35 ft/lbs to 'break' the clutched, then nest step would be to change oil and add a bottle of GM Limited Slip additive, do some figure 8's to disperse the additive about the clutches, and recheck breaking torque.
If still less then 35 ft/lbs with torque wrench, then clutches are shot along with springs.
If replace clutch pack, adjust each axle gear separately for 0.006" backlash, then assemble carrier.
Old Apr 19, 2013 | 10:15 PM
when mine went the other tire didnt turn at all.
Old Apr 19, 2013 | 10:52 PM
Chaotic94's Avatar
September 2011 ROTM
When it's in neutral, the other tire doesn't spin. If its in gear, the other tire spins opposite.
Old Apr 19, 2013 | 11:04 PM
lol, never occured to me to put it in park and try and spin i knew the clutch was not working.
Old Apr 20, 2013 | 04:43 PM
If the tire requires very little effort to spin with trans in gear, then clutch pack is toast.
The reason the tire does not spin with trans in neutral, the other tire brake is dragging.
Old Apr 20, 2013 | 07:36 PM
the one wheel burnouts where a pretty obvious indication on mine. lol
bohuntr
May 24, 2023 08:22 PM
lightningcruiser
May 27, 2012 07:54 AM
tttttt
Jun 5, 2011 01:33 PM
bbailey4life
May 14, 2006 02:05 PM
97_Z28
Mar 2, 2005 09:22 AM
