Clutch/Transmission Noise
Old 08-30-2012 | 08:44 AM
cdnturboz's Avatar
Default Clutch/Transmission Noise
Got my newly rebuilt lt1 together, installed new clutch, machined flywheel, throwout bearing, pilot bearing, and slave and master cylinder.
Bled everything last night and clutch pedal felt great.
Drove it up the drive way (its quite long), and worked good for the first pass but then when shifting I heard a clunk coming from the transmission area.
Once car was stopped and just idling you can hear almost a clunking/chatter coming from the transmission area. When clutch is depressed in it goes away.
Any thoughts?
I was thinking maybe the shift fork became loose?
Thanks
Steve
Old 08-30-2012 | 10:50 AM
cdnturboz's Avatar
While sitting here at work I had another quick question.
On the new throwout bearing the shaft where the fork would ride on kinda has a point on it (ie its not fully round) Is there a certain spot that that point should go in relation to the clutch fork?
imcdowel
12-17-2010 10:35 PM
Envisi0n91
03-06-2010 05:42 PM
d98camaro
03-09-2008 12:09 PM
Rise65
11-08-2007 10:58 PM
VTownSuzieQ
12-08-2006 07:24 AM
Quick Reply: Clutch/Transmission Noise
