Automatic Transmission Slipping
Old May 28, 2014 | 03:42 PM
Ash05's Avatar
Angry Automatic Transmission Slipping
99 Camaro with a 3.8L Engine is having an automatic Transmission Slipping problem. When you go from park into Drive it takes a 3-5 Second delay before it goes into drive. Then while you are driving the car it peridocally pops out of gear and send the rpm's shooting up and kicks back into gear. Please Help Quickly with this problem.
Old May 28, 2014 | 04:23 PM
You described a failing seal prefectly. You need a rebuild.
You can try changing the fluid and putting in a new filter. Sometimes that ups the internal pressure enough to make it last a few more months. Sometimes is does nothing.
bvans
70-81 Transmission & Differential
Feb 9, 2011 04:11 AM
shinwolf14
Nov 30, 2009 09:49 AM
YoungDriver
Sep 3, 2009 09:37 PM
neva_aquainted
Aug 18, 2008 11:28 AM
Hyde_GT
Oct 15, 2006 11:30 AM
