Another 4l60e Swap question..
Old Jul 23, 2022 | 07:33 PM
Mfoge5's Avatar
Lightbulb Another 4l60e Swap question..
I recently bought my son a 94 Z28 and soon after the 3-4 clutches burned out. I dropped the tranny and changed the clutches and did some other minor fixes and upgrades to it but when I goto reassemble it I noticed the PWM stamp on the pump. I checked the numbers and my assumption that it was stock was wrong and it is from a 95. My question is is there a way to use this tranny since I have it out and apart? Can I get the pump, valve body and wiring harness from a 94 and put it in this housing?? Or is it possible to use this valve body and harness and delete the TCC solenoid? Can I still use this torque converter? I know there are tons of swap questions but I couldnt find this answer so I thank you for and help and info in advance..
Curt705900
Jan 15, 2013 11:17 AM
CrimsonRevolver
Jun 22, 2011 02:59 AM
seawolf8
May 16, 2011 10:04 PM
camaro+supra=super
Jun 11, 2009 10:28 PM
camarro
82-92 V8 Tech
Jun 25, 2006 11:34 AM
