95 camaro bleeding
Old May 26, 2013 | 12:11 AM
Alewis95's Avatar
Default 95 camaro bleeding
hi everyone,
im new to the forums, and im having a little problem. i have a 95 camaro 3.4L 5 speed. i've replaced the transmission, clutch master and slave, clutch, and pressure plate. it was hard shifting into first gear and would grind going into reverse unless i threw it into 5th first. now after replacing all that its hard going into all the gears and its grinding. its no better than when it was when i started. please any help to fix this i'll take it. i've bled it several times following the proper instructions. unbolt the slave cylinder and keep it lower than the master cylinder and pump it while watching for bubbles in the reservoir. i pumped it until no more bubbles were popping up and still pumped it some more for safe keeping and there's still not alot of clutch
Old May 26, 2013 | 05:18 AM
hay alewis welcome to the forum. i moved your thread to the 4th gen transmission section. i know theres another way to bleed it i just cant find the thread. maybe one of the other guys can help out.
djsquare1
Aug 28, 2013 10:38 AM
snowell
Apr 9, 2011 06:42 PM
Sante
Aug 24, 2010 07:03 PM
BasicConcepts
Mar 16, 2010 09:59 AM
slpcamaro
Feb 19, 2008 06:34 PM
