94 v6 problems.
Old Mar 29, 2013 | 01:29 AM
Psychocisko's Avatar
Default 94 v6 problems.
So, I have a 94 3.4L Camaro with an auto. I picked it up for free from my dads friend who owns an impound lot, so I don't know a lot of history on the car. In the beginning, the transmission just leaked from the front, and shortly after it began to slip when accelerating from a standstill. Also, when transitioning from Park to Drive or Reverse, the car kinda... clunks and lurches into gear. But it doesn't have any shifting issues besides that. And also I should point out that my car idles high, around 2000-2300 (Once it is put into drive, the RPMS go back to normal). I've been hearing that it could be my torque converter, Any thoughts?
Old Mar 29, 2013 | 08:36 AM
sounds like you have more than one issue. trans pump, vacuum leak, carrier bearing come to mind.
Old Mar 29, 2013 | 08:56 AM
And the high idle is why you're getting a clunk when shifting into gear. Consider that "normal" under the circumstances.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
